Discussion topic: Conversion Kit
This message was authored by: MichellePee
Conversion Kit
Moving home this week, when I tracked my move it says I have had a conversion kit delivered. I can't find anything? Is it me or should I have recieved a box or is it something sky do in the air?
Re: Conversion Kit
@MichellePee  The conversion kit is just a ethernet cable. Sounds like you are moving to full fibre?
Re: Conversion Kit
@MichellePee
As @Highlinder indicates, if you are moving to FTTP, already have a Sky Broadband Hub and don't opt to add the WiFi Max subscription supplement to the account then Sky just send out an ethernet cable to connect the Hub to the ONT ('fibre modem')
