Discussion topic: WiFi help
Message posted on 25 Sep 2025 07:38 AM
WiFi help
My WiFi is constantly dropping out, it works, then stops, this has been going on for a few weeks now
Message posted on 25 Sep 2025 07:40 AM
Re: WiFi help
@Sarah532
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
