Discussion topic: WiFi has been so so bad for weeks
This message was authored by: SarahOffer25
I have never had issues with my internet but over the past 6 months it's been getting progressively worse. The last two weeks I have had to turn the wifi off on my phone and use 5G because it is so bad! We have to restart the router everytime we want to watch tv and still get buffering every minute or so. My partner cannot even think about playing on his PlayStation because nothing loads! However the checker says my broadband is great and my wifi is good. I've gone through all of your tips and tricks but need help. I pay a lot for my broadband and I am not getting a decent service at all! Please help me.
Avatar for SarahOffer25
Level 0 icon
Re: WiFi has been so so bad for weeks
Have to admit. I thought I was sending that to Sky! Anyone know how I can contact them?
@SarahOffer25
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
@SarahOffer25 If you need to contact sky, just dial 150 from your landline phone, same if you have a sky mobile, both will get you to sky Customer Service!
