Discussion topic: WiFi fibre
This message was authored by: RJG0311
WiFi fibre
Recently upgraded to WiFi fibre, devices struggle to stay connected upstairs, never had issue before? Drops off back to 5 g regularly.
can I get a booster?
Re: WiFi fibre
@RJG0311
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Re: WiFi fibre
@RJG0311 If you had it all working before the FF upgrade, had the same sky Hub and then the change off position from A to B off that hub if that is the case, it would be advisable to see if moving the hub back to where it was before is an easy or impossible thing to do!
If you upgraded and swapped the hub at the same time ie went sky Max then completely different scenario!
