Discussion topic: WiFi faulty
This message was authored by: Anthon2
WiFi faulty
My WiFi is constantly going off we can't watch tv
Re: WiFi faulty
@Anthon2
The lines may be busier than usual due to the damage and disruption caused by Storms Éowyn and Herminia which will also impact any Openreach visit.
Avatar for Anthon2
Level 0 icon
Re: WiFi faulty
Tried everything need someone to come out and look at it think the WiFi box is broken
Re: WiFi faulty
@Anthon2
You'll need to contact Sky. We are fellow customers here.
