Discussion topic: WiFi failing
This message was authored by: John070269
WiFi failing
My WiFi has started to fail on a daily basis, but everytime you check it come back ok?
Re: WiFi failing
@John070269
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
Re: WiFi failing
@John070269 May be time to call sky then and have them run a diagnostic from there end if you are not seeing anything when you check it!
