Discussion topic: WiFi extremely slow
This message was authored by: Julie4690
WiFi extremely slow
Since changing to Sky broadband super fast my WiFi signal is only one 1 bar and is really slow. I have to disconnect from WiFi regularly to connect and/or improve speed which is eating into my data and is unacceptable. What can I do? I am finding it really difficult to speak to someone to explain and obtain some help/advice.
This message was authored by: HiHowAreYa
Re: WiFi extremely slow
Hi, what device are you using so I can check it's specifications.
Avatar for Julie4690
This happens with both my iPhone SE and my husbands IPhone 15,  I have attached a photo of the tests which shows my phone on 1 bar
Hi, can you login to your sky hub, and disable the 5G WiFi. test and report back.
I have no idea how to log into my sky hub. Please advise
Open your web browser and type into the address bar 192.168.0.1
Login name : admin
Password is either on the back or bottom of the router.
Thank you, I have managed to log on, how do i disable 5g?
Hello, are you able to advise how to disable the 5g please
I have managed to find out how to disable by googling the answer myself, what report would you like? I don't see any difference in my connectivity
