Discussion topic: WiFi extenders
This message was authored by: JcBoy
WiFi extenders
I have two BT extenders but when I installed the new Sky Hub the extenders still show the name of the old Sky Hub. How do I change the names of the extenders?
Re: WiFi extenders
@JcBoy
I'd think you'd need to reset them back to factory default and then install them again, but how that's done will depend on the particular model involved.  Typically it would necessitate holding down a button somewhere.
Avatar for JcBoy
Re: WiFi extenders
Thank you. I'll have a look to see if there are any reset buttons. I tried switching it off and on again but that didn't work.
