3
This discussion topic has been answered Discussion topic: WiFi drops out when using the land line
This message was authored by: colin+gardener
If we're watching iplayer, or YouTube, or something similar, and the the land line phone rings, our WiFi stops working and we lose connection. After the phone call is completed the WiFi signal will return. Do I have a problem with my land line?
Avatar for colin+gardener
This message was authored by: colin+gardener Answer
Re: WiFi drops out when using the land line
All connections are correct. I have no problem with the phone, and use filters.
@colin+gardener how is your phone connected? If it is still plugged intomthe old phone socket as opposed to into the Sky hub the issue is likely to be the lack of a proper line filter. This used to be a common issue but less so now due to prefiltered phone sockets ( these have a separate connection for the phone and the hub)  and even more so now digital voice lines via the hub should avoid such things.
Sky no longer provide filterscbut they can be bought from hardware stores.
@colin+gardener filters can go bad so replacing your's would be a sensible next step. After that its checking to phone wiring in your home or getting Sky to arrange fitting a filtered master socket.
