Discussion topic: WiFi drops off despite it's all fine
Message posted on 13 May 2025 11:14 AM
Message posted on 13 May 2025 11:18 AM
Re: WiFi drops off despite it's all fine
@Nadimhussain
If you’re not already aware the Sky Community is a customer led discussion forum where Sky customers are available to help other customers and you aren’t contacting Sky Customer Services.
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
