Discussion topic: Intermittent Wi-fi signal from router and 3rd party Mesh
This message was authored by: thirstytin67
Intermittent Wi-fi signal from router and 3rd party Mesh. Glass TV keeps dropping out seems ok on the ethernet cable.
Re: Intermittent Wi-fi signal from router and 3rd party Mesh
@thirstytin67
If your Glass TV works fine on ethernet then this suggests your connection is stable. If the WiFi is dropping out on a 3rd party mesh system it sounds like that could be the culprit.
I am NOT a Sky Employee
Avatar for thirstytin67
Thanks for the responce. Its also effecting the Wi-Fi from the router. Glass seems to struggle every now and then. Sky router never seems to show different speeds when I do a test which is a bit odd...have changed setting on the chanel but I do suspect it could be a 2.4Ghz /5 Ghz  confliction on different device via the Mesh. l also have a Nest that keeps losing connection recently. But I do think a new Mesh will be required soon as have had a few years now.
@thirstytin67
Is there a reason you are using both the Sky Hub's WiFi & a 3rd party mesh system? You should only really be using one system at once otherwise there may be clashing
Hi  James,
Thanks for you help.
Purley because the Sky is not reaching the other rooms. I need Eth connection for work Laptop. We have a 1960 house concrete block walls. Has always worked ok tbh until now.
I had 3 mesh nodes working brillantly accidently I fried one with wrong power adaptor (Schoolby Error) But was ok on the 2 Nodes for at least 2 years.
Maybe I could restrict the Sky Wifi
Cheers
