Discussion topic: WiFi dropping
This message was authored by: StuartLondon27
Message posted on 13 Dec 2025 05:01 PM
WiFi dropping
Hi, my WiFi seems to drop really low. I even tried to buy the Fibre upgrade but Sky cancelled it for no reason. What can I do to improve the WiFi. I'm happy to upgrade but it's Sky that seems to be stopping me doing so. Thanks.
Find out more
Message posted on 13 Dec 2025 05:27 PM
Re: WiFi dropping
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
