Discussion topic: WiFi dropping
Message posted on 11 Jun 2025 01:03 PM
WiFi dropping
I recently upgraded from fibre 150 to full fibre 500. Scone the upgrade I have had nothing but issues with the speed and signal. When I reset the router it shows I have a speed of about 480mbs but the after a couple of mins this drops to around 280mbs and this is from standing 3ft away from the router. I have had a new router sent out and it hasnt made and difference. The same things have happened every time. I have also changed the channels to no avail. Technical department just keep saying reset the router, driving me up the wall. I have also been sent out a signall extender and nothing
Message posted on 11 Jun 2025 01:55 PM
Re: WiFi dropping
@Ram3 What is it that you are using to check the speed with to the hub!
Message posted on 11 Jun 2025 02:49 PM
Re: WiFi dropping
Mobile, tablet and an Xbox via wifi
Message posted on 11 Jun 2025 02:52 PM
Re: WiFi dropping
Using fast.com and speed checker
Message posted on 11 Jun 2025 03:01 PM
Re: WiFi dropping
@Ram3 What does the last 30 days history look like with your service checker.
Message posted on 11 Jun 2025 04:51 PM
Re: WiFi dropping
Coming into the house is fine, it's the WiFi. Speeds were better when I was on the 150 but now getting less. Went through everything with sky and am paying extra for the boost which gives me free engineer service been paying that for years. Just asked for an engineer to call out to look at it to be told they don't supply engineers in my area and nothing they can do so just going to move provider
Message posted on 11 Jun 2025 04:55 PM
Re: WiFi dropping
@Ram3 Saw the answer on your other post!👍
