Discussion topic: WiFi dropping out repeatedly
This message was authored by: BP202525
Hi,
My WiFi continues to drop out and then return, noticed on a couple of devices, including my Smart TV.
My Google TV notification pings saying "connection lost" and then "connected" multiple times whenever watching TV, dropping out for 10-60 seconds on average I would say.
I have lived here for 3 months and this issue has been ongoing. It also impacts my EV charger from losing and disconnecting on WiFi.
Less noticeable on smart phone etc.
Router is plugged into master socket and is 1 metre from the TV. A new master socket was installed 3 months ago as part of the house renovation.
Help!
 00:00:48 syslog: [ 42.914000] Line 0: xDSL link down
00:00:48 syslog: [ 45.917000] Line 0: xDSL G.994 training
00:00:49 syslog: [ 48.923000] Line 0: xDSL link down
 00:00:58 syslog: Voice Configured
00:01:00 syslog: [ 59.923000] Line 0: xDSL link down
00:01:04 syslog: Voice Initialized
00:01:04 syslog: Voice Connecting
Re: WiFi dropping out repeatedly
Hi @BP202525
Can you post your router stats please
I am NOT a Sky Employee
Avatar for BP202525
Router Statistics
System Up Time: 44:37:19
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time
WAN MER 3707863 9559704 0 23336 56421 44:35:13
LAN Down 0 0 0 0 0 00:00:00
WLAN (2.4 GHz) Up 5715326 1385297 0 7874 3150 44:35:29
WLAN (5 GHz) Up 4794564 2831722 0 0 51179 44:35:28
Broadband Link Downstream Upstream
Connection Speed 24425 kbps 3637 kbps
Line Attenuation D1(23.2 dB) , D2(67.5 dB) , D3(90.3 dB) U0(9.4 dB) , U1(53.6 dB) , U2(0.0 dB)
Noise Margin 2.2 dB 5.9 dB
Avatar for BP202525
Is this what you needed?
@BP202525 Can you also check the BTW site, use the address checker option and post! Hide any personal info!
BT Broadband
Avatar for BP202525
Is this ok?
@BP202525 Will take a look when your picture gets cleared for viewing!
