Discussion topic: WiFi dropping and reconnecting constantly
This message was authored by Richard6882024 This message was authored by: Richard6882024
Countless times thought the day, my WiFi is dropping out and then reconnecting within 5 minutes. The 2nd and 4th lights go amber and then return green a short while later. This is a major issue when on work calls, trying to do work, or streaming films etc as it ruins the experience on all, in particular work calls which can be very frustrating.
This message was authored by mae-3 This message was authored by: mae-3
Re: WiFi dropping and reconnecting constantly
@Richard6882024
Check the router placement, and identify anything that may be causing WiFi interference, eg: microwaves, Bluetooth devices and cordless phones. Check cables to the phone socket or ONT and change these to rule them out. If all else fails you'll need to contact Sky as you may have a line fault.
Zen internet on FTTP (900Mbps down, 100Mbps up). SAT> IP (Apple 4K 2nd gen TV to LG C1 OLED UHD TV/Dolby Atmos Denon AVR, DacMagic Plus for Hi-Res audio), hosting own blog/forum (cluster), OPNsense & Zenarmor L4/L7 NGFW & DPI IDS/IPS, Asus ET12 Pro Tri-Band wifi, Linux, Gamer: Xbox Series X/i7 laptop, round-robin DNS over HTTPS, non-proprietary VoIP HD AMR-WB (G.722.2) and more... Beta tester Apple iOS/watchOS/tvOS/iPadOS/macOS. Dr Mae-03 PhD.
