Discussion topic: WiFi dropped
This message was authored by: LauraD85
WiFi dropped
Looks like lots of people are complaining about WiFi/broadband dropping despite your website checker saying that everything is fine! Please can you update with service issues asap!
Re: WiFi dropped
@LauraD85
You may not be aware but you haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to assist other customers.
Even if you’ve already tried it use this link to check if there are any issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
This message was authored by: Trevlar
Re: WiFi dropped
I also have no Internet at home. Please can this be check CR0 8B. Thanks
