Discussion topic: Internet connectivity patchy
Message posted on 18 Jun 2026 10:34 AM
I recently was updated to a hub 6 from a hub 4. Now my internet connectivity is problematic. WiFi no issue signal strength is good through out the house. Devices however report the WiFi has no internet. Broadband checker in My Sky reports no issue. On the hub 4 I could get a report of the connection speed up and down of the modem. I can't find that data on the hub 6 but since the update the connectivity has been worse.
Message posted on 18 Jun 2026 11:49 AM
Re: Internet connectivity patchy
Hi @SimonHall
Do any lights on the hub change when you have the problem or is it just the actual WiFi signal dropping? The Hub 6 has less parameters you can look at yourself from the interface so you have to rely on Sky's tools.
