Discussion topic: WiFi dropped out 1:50am
Message posted on 02 Feb 2025 12:55 AM
My WiFi has dropped, the sky app test my broadband service says there is nothing wrong, yet I am looking at 2 orange lights and 2 green lights for about 5 minutes now and no change, this is constant with sky now, I will be leaving them permanently, as I have a stearming tv with them without the sky package and I can't even watch tv without it being blurry, paused because of single disruption or WiFi drop out, it's disgusting that I am expected to pay for unusable services.
Message posted on 02 Feb 2025 05:26 AM
Re: WiFi dropped out 1:50am
If it's happening at the time you've posted it's possibly maintenance related. This is done overnight to minimise disruption as most customers are asleep. If it's not back up by the time the phone lines reopen use the below link to check to see if there are any outages nearby https://www.sky.com/servicechecker
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
