Discussion topic: Internet not working
This message was authored by: Eloise3
Hello,
my WiFi seems to be working with my TV but not with mobile devices in my home!
This message was authored by: DeepakSingh
Re: Internet not working
Same here .. wifi not working in any device. Bad service !!
Avatar for Eloise3
Bad times... did a WiFi check and apparently its "good" haha! Its the complete opposite!!
True.. something is wrong with machine checks and actual fact on ground!! Get your system checks up to date Sky!!!
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
