Discussion topic: WiFi drop out
This message was authored by: Aj116
WiFi drop out
My WiFi drops out at the same time every night for about three hours then reconnects. Any ideas why this is and how to stop it from happening?
Re: WiFi drop out
@Aj116 Are you using anything like a sky Q/mini for hotspot that is going into eco mode for power saving?
Using the standby settings | Sky Help | Sky.com | Sky Help | Sky.com
Avatar for Aj116
Re: WiFi drop out
No nothing used
Re: WiFi drop out
@Aj116 Can you supply more specific details, when it happens, how you know that it is happening and what you are seeing, would also be helpful to know what equipment that you are using on the connection!
