Discussion topic: Hub not connecting to internet.
This message was authored by: VickieF13
My hub won't connect to the Internet but the sky app and website say everything is fine. This has been happening for the last 2 days, keeps being off for an hour at a time!
Re: Hub not connecting to internet.
@VickieF13
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
If this is of no help give Sky a call to report it to them.
Avatar for VickieF13
Re: No wifi
I've done all that. Sky said to give them 72 hours. Then closed the case this morning as the Internet was back on, but now it's down again!
Re: No wifi
@VickieF13 Please do not create multiple post's it does not help in the slightest!
Re: No wifi
@VickieF13
I have moved you reply back to the thread you started on this issue.
What is the result of the line test now ?
