Discussion topic: WiFi drag
This message was authored by: Pgm
Message posted on 29 Dec 2025 05:26 PM
WiFi drag
Broadband keeps buffering. So much for fibre!
Find out more
Message posted on 29 Dec 2025 05:28 PM - last edited: 29 Dec 2025 05:33 PM
Re: WiFi drag
Fibre-optic cable (or any physical bearer) is by definition not WiFi.
If you now have the white Max Hub, numerous posts suggest its wireless output underperforms in some properties.
Message posted on 29 Dec 2025 06:42 PM
Re: WiFi drag
@Pgm Not here it does not, so you need to look why you have the issue. Fibre runs full speed 98% off the time and never buffers!
