2
This discussion topic has been answered Discussion topic: 2.4 Ghz
This message was authored by: Olly25
2.4 Ghz
I can't find a login or password for my sky router, I need to activate the 2.4ghz band for some of my smart devices. Can anybody help me please?
This message was authored by: belfastjoc Answer
Re: 2.4 Ghz
Use Admin and WiFi password
Re: 2.4 Ghz
Re: 2.4 Ghz
@Olly25 The 2.4Ghz is on by default with the 5Ghz and may be single ssid, depending on the latest two router's then yo cannot seperate but you can temp disable if required.
Find, change or reset your WiFi password | Sky Help | Sky.com | Sky Help | Sky.com👍
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
