Discussion topic: WiFi down
This message was authored by: Colin011
WiFi down
WiFi hasn't been working all day, just unplugged and restarted it, came back on for maybe 10 min then off again
Re: WiFi down
@Colin011
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
