Discussion topic: WiFi down
Message posted on 24 Nov 2025 06:36 PM
WiFi down
WiFi is down
Message posted on 24 Nov 2025 06:41 PM
Re: WiFi down
@Sommer3
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
