Discussion topic: WiFi down
Message posted on 22 Oct 2025 12:13 PM
WiFi down
Wi-Fi box is on and all green but not working, devices can't get internet from it
Message posted on 22 Oct 2025 12:19 PM
Re: WiFi down
@Laurenb4
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
Message posted on 22 Oct 2025 12:25 PM
Re: WiFi down
My internet also stopped working around noon like Lauren's and still has not come back, which suggests the problem is with the broadband. Please investigate.
Message posted on 22 Oct 2025 12:37 PM
Re: WiFi down
Mine is working again all by itself. Hope the same for others
