Discussion topic: WiFi down
This message was authored by: Ashleylewis1016
WiFi down
My WiFi has just gone down 10 mins ago. On multiple devices. Have tried multiple devices and restarted my router
Re: WiFi down
@Ashleylewis1016
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
