Discussion topic: WiFi down
This message was authored by: RobertHowarth
WiFi down
No signal at all from WiFi therefore the tv is down too as we have sky stream
Re: WiFi down
@RobertHowarth
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
