Discussion topic: WiFi down
Message posted on 09 Jun 2025 10:44 PM
WiFi down
WiFi down - seems to be a wide spread issue 🤦🏻♀️ anyone have any idea as to how long it's likely to be down for . Both me and my partner work from home so really rely on the WiFi being up and running 🤦🏻♀️
Message posted on 09 Jun 2025 10:49 PM
Re: WiFi down
My sky is down too and as I have sky stream I have no tv.
Message posted on 10 Jun 2025 05:06 AM
Re: WiFi down
@Lang0528 @Michaelm3
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
