Discussion topic: I've got two green and two amber lights, with no WiFi
This message was authored by: Gary1100
My WiFi is down two lights are green and two are amber
Moderator note: subject of thread updated to better reflect the conversation
Re: A
@Gary1100
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
