Discussion topic: WiFi down
This message was authored by: Alex+Lea
WiFi down
Only two lights on router and no WiFi
Re: WiFi down
@Alex+Lea
There is a problem in the south of Cornwall if you're in that area.
Otherwise, if you haven’t done it already use the below link to check to see if there are any problems or outages nearby
