Discussion topic: WiFi down
This message was authored by: GT387
WiFi down
Is anyone's sky broadband down ? Not sure if it is the weather or something else ?
Re: WiFi down
@GT387
The lines will be particularly busy at present due to the damage and disruption caused by Storm Éowyn.
Avatar for GT387
Re: WiFi down
What is the number to call if you don't have a sky talk phone
Avatar for GT387
Light
Can anyone tell me what slowly flashing yellow light means in my router ?
Re: Light
@GT387
See this link depending on which hub you have
Avatar for GT387
Ridiculous!
Does anyone have a number where I can get talking to an actual person. Not a computer
Re: Ridiculous!
@GT387  there isn't one as with most companies all sky numbers start with the automatic voice
stay on the line as long as possible don't say anything when prompted and you will be put through to the next available agent
Re: Ridiculous!
@GT387
All calls start with an automated set up. If necessary say nothing when prompted and don't hang up.
Avatar for GT387
Re: Ridiculous!
Do you have a number ?
Re: Ridiculous!
@GT387
If you've already discovered it starts automated then you've already rung it. To call Sky dial 150 (free) from a Sky Talk landline or a Sky mobile or alternatively use the following link which will lead to contact details which will hopefully (but not always unfortunately) include a phone number
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number.
The posting of full phone numbers isn’t permitted on the forum.
Any calls to Sky will initially be automated which may try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Alternative means of contact are:
(a) through the Sky Virtual Assistant on the same page - depending on your query, which can connect you with a live agent virtually if necessary or provide you with the contact number or
(b) via Skys social media sites (the links are at the bottom of this page).
