Discussion topic: WiFi down in Belfast
Message posted on 24 Feb 2025 11:36 AM
App says there is issues, but when I scan on the app to check services, it says all is fine. But broadband/wifi isn't working.
Message posted on 24 Feb 2025 11:39 AM
Re: WiFi down in Belfast
@DM19791
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
