Discussion topic: WiFi down although Sky says it's okay after running diagnostics !!!
Message posted on 09 Oct 2025 02:15 AM
I have no WiFi
Run diagnostics and sky say no issues
is this a joke ?
Message posted on 09 Oct 2025 05:04 AM
Re: WiFi down although Sky says it's okay after running diagnostics !!!
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
If it's not, use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn't necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
If there aren't any then try running the line test here https://www.sky.com/help/articles/broadband-diagnostic-start
Once completed, if it reports back that all is good click on 'broadband' to run an updated test.
If you get amber or red you need to follow the on-screen instructions.
If you're still having problems you may need to contact Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it's still working.
This link providers information about the coloured lights on the various hubs https://www.sky.com/help/articles/hub-lights-explained-start
