Discussion topic: WiFi down again
Message posted on 12 Jun 2026 10:52 PM
WiFi down again
WiFi has gone off again
Message posted on 13 Jun 2026 03:15 AM
Re: WiFi down again
@Nic5
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
