Discussion topic: Broadband dropping out
Message posted on 12 Jun 2026 11:20 PM
Hello
My broadband is dropping out on multiple occassions throughout the day. It is immensely frustrating. Please look into this
Message posted on 13 Jun 2026 03:14 AM
Re: Broadband dropping out
@iamtom7447
You may not be aware but you haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to assist other customers.
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
