Discussion topic: WiFi down again
This message was authored by: Kerryk19
WiFi down again
WiFi not working again, 3rd time in 6 days
Re: WiFi down again
@Kerryk19
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
