Discussion topic: No wifi
Message posted on 09 Jun 2026 01:12 AM
No wifi
My WiFi has dropped tonight I've unplugged it left it for 5 mins then plugged back in. It sorted the problem for all of 5 mins and then it went again so I've reset it and now only two lights are showing. Will be leaving sky if this doesn't get sorted, this happens like 3 times every month
Message posted on 09 Jun 2026 07:27 AM
Re: No wifi
@Rhiannon37 loss of connection after midnight to 6am is often due to routine maintenance work by the network operator who are Openreach ir City Fibre. If thst is the issue then switching isps is pointless. If the issue is present at other times report it tonSky so they can get your line checked.
