Discussion topic: WiFi down again!
Message posted on 09 Jun 2025 05:26 PM
WiFi down again!
Fed up with Sky all that ever happenes is constant glitches with the WiFi going down
Message posted on 09 Jun 2025 05:34 PM
Re: WiFi down again!
@Rebecca142
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
Here's the same advice I provided last time…
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
