Discussion topic: WiFi doesn’t reach kitchen
Message posted on 24 Oct 2025 07:38 PM
Just got sky q in today and WiFi doesn't work in my kitchen only 9 meters away from hub
Message posted on 24 Oct 2025 07:50 PM
Re: WiFi doesn’t reach kitchen
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Message posted on 24 Oct 2025 08:13 PM - last edited: 24 Oct 2025 08:16 PM
@Kathy__ Sky Q is TV, not anything to do with broadband! Did you also have broadband installed at the same time? Depending on which sky Hub you had installed the 9Metre distance may not reach the area that you need wi-fi in also!
