Discussion topic: WiFi distance
This message was authored by: Ricbarks
WiFi distance
My WiFi doesn't work any more than 6-7metres away from the hub
Re: WiFi distance
@Ricbarks
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
