Discussion topic: Broadband outage
This message was authored by: Spence5
Broadband outage
I'm in Watford, ONT LOS is red but t broadband checker is showing as good service.  What do I do next?
Re: Broadband outage
@Spence5
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
