Discussion topic: WiFi cutting out
This message was authored by: KTB3
WiFi cutting out
At least once a day I loose connection, which affects working from home. I have checked all connections and no issues reported. Any advice please?
Re: WiFi cutting out
@KTB3 unless there are other symptoms Openreach are unlikely to consider one line drop per day as a fault. Unfortunately thst you use what is sold as a domestic connection for work does not give you any priority. Your line is monitored by automatic systems that should keep the line stable it is only when that system fails will engineers intervene Sky have no control over that decsion,
If you post your Sky hub's stats forum members maybe able to advise on **bleep** maybe wrong see Find your Sky Broadband router statistics
