Discussion topic: My internet keeps cutting out
Message posted on 14 Jul 2024 10:06 PM
Message posted on 15 Jul 2024 07:37 AM
Re: My internet keeps cutting out
@Nova2020 you can run a connection test by logging into the My Sky app while the connection is up if it finds a line fault it can book an engineer saving you a call. It will also tell you if Skyvare aware of an issue affecting your line. Otherwise you can call Sky. They only pay compensation for complete loss of connection if thecfault is not cleared after 2 full working days after you have reported tge fault. This is as recommended by Ofcom see Customer Auto-Compensation | Sky Help | Sky.com
Message posted on 15 Jul 2024 08:41 AM
Hello, so what if it's been doing for the past couple of months keeps cutting in and out so yeah I think I should be owed some money as like I said I'm paying for a subscription that I should be getting full use off witch I'm not
