Discussion topic: WiFi cutting out intermittently
This message was authored by: Claire339
The wifi randomly comes and goes and teams calls cuts out, our phone wifi cuts out and our TV stick cuts out
Re: WiFi cutting out intermittently
@Claire339 most likely issue is poor wifi signal where your devices are. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
