Discussion topic: Ring doorbell
Message posted on 20 Oct 2025 07:35 PM
Ring doorbell
Message posted on 20 Oct 2025 07:39 PM
Re: Ring doorbell
@babyeric wrote:
I've recently changed my broadband
Do you mean you have changed your broadband supplier, if so you need to use the ring app and change the wifi network via it.
Message posted on 20 Oct 2025 09:14 PM
Re: Ring doorbell
@babyeric You need to use the ring app and change the required information, this has nothing to do with sky, and you also need to be sure that you have a good 2.4Ghz wireless wi-fi signal, only one doorbell is able to go higher. Ring support is your place to go as well! Ring device health and change network!
Message posted on 20 Oct 2025 09:33 PM
Re: Ring doorbell
@babyeric the well publicised issue today with AWS affected Ring systems my own is back online but was down from early morining.
