Discussion topic: WiFi cutting off
Message posted on 25 Aug 2024 02:16 PM
WiFi cutting off
My WiFi is cutting off every 1-2 hours. I run the test and it shows everything is fine but it is not. It is annoying. No help from SKY. It started on Friday.
Message posted on 25 Aug 2024 02:29 PM
Re: WiFi cutting off
@Mikolaj2black or white router from Sky?
Message posted on 25 Aug 2024 02:31 PM
Black router. Normally 3 green lights but when cutting WiFi off only one green light left and then coming back to three green lights. I restarted router too.
Message posted on 25 Aug 2024 02:36 PM
@Mikolaj2 Could you please post your router stats following the link below.
Message posted on 25 Aug 2024 03:19 PM
Message posted on 25 Aug 2024 04:06 PM
Those aren't your router stats.
Message posted on 25 Aug 2024 04:20 PM
@Mikolaj2 You need to follow the directions above all the way to the end as it shows you in the link what it should look like.
