Discussion topic: WiFi continously dropping out
This message was authored by KevR88 This message was authored by: KevR88
WiFi dropping out every 20 minutes or so
Re: WiFi continously dropping out
@KevR88  black or white router from Sky?
This message was authored by sirxnad This message was authored by: sirxnad
I have the same problem. White Sky router
@sirxnad Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
