Discussion topic: WiFi constantly dropping
Message posted on 06 May 2025 12:57 PM
Our WiFi is constantly dropping. We are trying to work from home, the service checker sees no issue, but it is at least every 5-10 minutes it drops out for a few minutes.
there is no contact number to report and issue or put you through to an actual person.
we need urgent help as this is happening most days.
Message posted on 06 May 2025 01:04 PM
Re: WiFi constantly dropping
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
To call Sky dial 150 (free) from either your Sky Talk landline or a Sky mobile. Alternatively use this link…
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a number starting 0333.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number. (Customer Services in the ROI are not open at weekends).
The forum filters don’t allow the posting of full phone numbers on here.
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
