Discussion topic: WiFi constantly dropping
Message posted on 14 Apr 2025 06:15 PM
Message posted on 14 Apr 2025 06:21 PM
Re: WiFi constantly dropping
@Kandice1
Wi-Fi is the connection between devices and your router. Broadband is the internet connection provided by your ISP to your dwelling.
This should determine if there's an identified fault affecting multiple households.
